This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Matchsearch report in XAL 3.5
I want to create a report showing the results of a Matchsearch Form.
How can i transfer the index from the form to the report.
the report shows the intire table insted of only the ones selected in the form.
  • When a Matchsearch Form finds a "good" record the record is inserted in a temporary index.
    You have to use the name of the temporary index within the report to get the same result as in the form!
    But be carefull. You can only use the temporary index within the Matchsearch Form as (normaly) the generated index is deleted when you exit or arbort the form => take a look at the exit and abort trigger.
    Hope this information can help you. :)
    Regard,
    Michael
Related
Recommended
