This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Missing File, C_TXTDAT.*
I get the following message when trying to open a system DSN from ASP towards Concorde XAL 2.60:
Microsoft OLE DB Provider for ODBC Drivers (0x80004005)
[Simba][Simba ODBC Driver][Codebase File Library]Missing File, C_TXTDAT.*
However, the C_TXTDAT.SE file *is* in the same directory as the database file C_DATA.DAT. Is there anyone who knows how to solve this?
  • Hello Stefan,
    You have to include the path to the system directory for XAL in your ODBC setting.
    Now, i don't remember exactly all settings for the XAL-ODBC but i'll give it a try.
    In the fild were you specify the path to C_Data.dat, include th path to your XAL system directory (even if is is the same directory).
    c:\xalwin\c_data.dat -dc:\xalwin\
    Let med know if you still got problem, then i'll check it out better at home.
    /Peter Karlsson
