This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Transfer between datasets
How do I transfer an item from the stocktable in one dataset to the stocktable in another dataset.
TIA
Dino
  • Hi,
    you could use something like this:
    #MacroLoad(C_UTIL)
    introduce Stocktable[itemidx, '0101']
    process #PROC_DBChange 'Mode=Temp File=DMO PROC=24 args=xal=StockCreateItem' using Stocktable
    in the job StockCreateItem you could use:
    extern StockTable
    #DBUpdate(StockTable)
    Orvar
  • quote:
    Also, if you are using an SQL database system (such as ORACLE) you can create a macro thus :
    #LocalMacro.SQLChangeDataSet
    IF #DB_File(FILESTR(%1),FILE)==0 THEN
    SET SQLPrepare("UPDATE "+#SQLTableName(%1))
    SET SQLPrepare("SET DATASET='"+%2+"'")
    SET SQLPrepare("WHERE DATASET='"+#DB_Dictionary(EXT)+"'")
    SET SQLPrepare(" AND "+#SQLRowNumber+"="+Num2Str(%1.RowNumber,0,0,0,0))
    SET &MacroInt = SQLExecute("")
    ENDIF
    #EndMacro
    If you had a stocktable record in dataset 'BOB' and wanted to move it to 'JIM' then you'd call it thus :
    #SQLChangeDataset(StockTable, "JIM")
    Be aware though that if the record breaks a unique index rule when moved you will get an SQL error.
    Barny
Related
Recommended
