This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Copy Line from Object Designer
Is the following possible ?
You are developing in a Navision database. When you change an object you also make a change in the version list of that object. At the end of the day, I want to copy (ctrl+c) those objects from the object designer and do a paste (ctr+v) in a table in another Navision database (to keep track of what you've done). So the goal is not to have the objects in that database but just the type, ID, description, version list and so on.
Can that be done ?
Gunther
Related
Recommended
