This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Transaction Import into Purchase Orders Maintenance screen (042500)
Hello,
I am tyring to do the Transaction Import into Purchase Orders Maintenance screen (042500), and I am not able to save
the data into the screen 0425007 (Purchases for Sales Order). It is the
screen where you enter the Sales Orders. I am able to see that the data is
being populated in screen 0425007 as well as 0425000 during the Transaction
Import, and for some reason it is not being saved in the 0425007 screen. At
the end of the process, it says there were 0 errors.
Here's my control file:
'$include: "bsl.dh"
'04250 Control Macro
Sub ProcessImportLine( LevelNumber%, Retval% )
  select Case LevelNumber
    case TI_Start
      Call AliasConstant( "Level0", "Order" )
      Call AliasConstant( "Level1", "Detail" )
      Call AliasConstant( "Level3", "POAlloc" )
    case 0 ' 0 of 4
      ' Field mask is UUUUUUUUUU
      serr = SetObjectValue( "cvendid", ImportField(2) )
      'serr = SetObjectValue( "xuser11", ImportField(2) )
      Call SetBufferValue("bPurchOrd.User2",ImportField(1))
    case 1 ' 1 of 4
       serr = SetObjectValue( "cpurchtype", "GS")
       serr = SetObjectValue( "cinvtid", ImportField(1) )
      ' NOTE  -- This field is a required field
       serr = SetObjectValue( "csiteid", ImportField(2) )
       'serr = SetObjectValue( "cqtyord", "" )
       'serr = SetObjectValue( "cunitcost", ImportField(5) )
       serr = SetObjectValue( "xuser1", ImportField(6) )
   case 3 ' 3 of 3
    'Level 3 if of Type D
      ' csonbr is a key field for level 3
      ' Field mask is UUUUUUUUUUUUUUU
      serr = SetObjectValue( "csonbr", ImportField(1) )
      ' csolineref is a key field for level 3
      ' Field mask is 99999
      serr = SetObjectValue( "csolineref", ImportField(2) )
     serr = SetObjectValue( "cmdOK07", "PRESS" )
   case TI_Finish
   End Select
End Sub
I really appreciate if you could help me. I have never worked on SL before.
Thank you for your time.
Hande Aksac
Related
Recommended
