Default dimension value not updating in journal line when created through Configuration Package
In the GL account card, I set PROJECT dimension value TOYOTA as default dimension with SAME CODE.
I used configutation package to create a journal, in the configuration package i have not included the dimension PROJECT using "Dimension as column" feature. Becasue since it is a default dimension value, not required to even keep that project dimension column.
In configuration package, after do import from excel, then done apply package. In journal, that default dimension value TOYOTA is not coming.
Pleae advise.
Note: i tested included the dimension PROJECT column also in configuration using "Dimension as column" feature, still not working
Vinoth
Related
Recommended
