How to delete change log entries in NAV 2016?
Using Nav 2016.  Is there away to delete entries in the change log entries?  I have 16 tables that have been configured to track entries.  Wanted to see if I can remove all entries for these tables back 7 days ago.
I have setup the Change Log, but on the intital setup of the 16 tables I didn't select Purge History older than.  If I go back and specify a data wil this work.
Just want to make sure the data isn't filling up database.
  • In NAV 2013 R2 the Change Log Entries can be deleted from Departments, IT Administration, Data Deletion, Delete Entries, Delete Change Log Entries... I assume it's still there in NAV 2016.
    You can enter date and/or Table No. filters. It does take a while to run and on NAV 2013 R2 offers no progress bar (because it's a processing only report, number 510).
    I would start with one month's worth of your oldest log entries to estimate the time it's going to take, then maybe do it in chunks of 3 months for e.g.
