Alternative Ship To address
Running Nav2009 SP1
Using RTC
If we post a shipment and have an alternative ship to address when we post the shipment the following error appears and the shipment note does not print.
"Rendering output for the report failed and the following error occurred: The hidden expression for the table 'table 4' contains an error. Input string was not in a correct format."
However if you go into Classic you can print it OK
Please help
