This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Consumption Problem
Dear Concern
I want to consume some raw materials with excise effect but there is no ouptput quantity of there Finished Item(i.e., FG),so that I can't create its Released Production Order and cant change its status to finished(because its showing me an error "You cannot finish line 10000 on Production Order RPO/0910/0003. It has consumption or capacity posted with no output." and I also cant do negative adjustment of these raw materials because by posting Negative Adjustment entries,it will not effect excise(means entries will not go in RG tables) but I want this.If it is possible with negative adjustment,then How can we achieve this? or any other solution to cunsume these entries with excise effect.
Related
Recommended
