Is it possible to dynamically change fields visible property in Business Central
Hi Experts,
Is it possible to dynamically change the fields visible property based on some boolean selection?
I have a scenario that in user setup I have a boolean field lets say "Hide Field"
If "Hide Field" is true then I have a (for eg) In Customer Card Name field will be hidden for some specific user? and this should be configurable for some other table and for any field?
I was trying to achieve this using fieldref but fieldref does not have visible property
https://docs.microsoft.com/en-us/dynamics-nav/fieldref-data-type#:~:text=FieldRef%20Data%20Type%20in%20Dynamics%20NAV&text=This%20complex%20data%20type%20identifies,any%20table%20in%20the%20database.
Table Name Field Name Hide Values
Customer  Name TRUE
Vendor Name TRUE
Item Unit Cost TRUE
Any suggestion?
Thank you
Related
Recommended
