Business Central Web Service Access On Premise
just upgraded from Nav2015 to BC14 on premise and have lots of web services - mostly codeunit integrating to local systems.
Using Windows credentials
On the application server I can enter the web service address in a browser using //localhost and see the xml.
I can also use the IP address from other pc's but NOT the proper server address.
When I do , using the windows name and password or the access key - it simply bounces back rejecting the authentication.
Any ideas how I can connect using the proper server name ?
I tried creating another instance using webservice key authentication and that did not work.
Related
Recommended
