Error on upgrade NAV2016 CUM3 to 365BC SPRING CUM4
 I am trying to upgrade a NAV2016 *** 3 database to 365BC Spring *** 4 database.
I follow the MS description as found here,
https://docs.microsoft.com/en-us/dynamics365/business-central/dev-itpro/upgrade/upgrading-the-data#UploadLicense
Everything works fine until Task 11, Synchronization. It runs for a short while and then ends with the following error:
"Sync-NAVTenant : A dead connection cannot be brought back to the livings"
Database size is 85GB. It should not be a SQL command timeout because I increased it.
I have tried the process on four different machines and get the same result. Using SQL Server 2014.
The NAV2016 database works fine and operational. I can compile all objects and synchronize before I start the upgrade.(I have attached screenshot with here)
Do you have any ideas?
Related
Recommended
