Initialization of new container fails
I really love working with Docker containers. Before I usually took 1-2 hours to be able to test out a new version. Now I can get a new version up and running in 5-10 minutes (depending how much it needs to download first).
But recently I have been having some issues. This is what it says is happening.
Starting NAV Service Tier
Using license file 'c:\run\my\license.flf'
Import License
Microsoft Dynamics 365 Business Central Server is currently not ready to serve requests. Try again later, or contact your system administrator.
at <ScriptBlock>, C:\Run\SetupLicense.ps1: line 29
at <ScriptBlock>, C:\Run\navstart.ps1: line 126
at <ScriptBlock>, C:\Run\start.ps1: line 107
at <ScriptBlock>, <No file>: line 1
TimeGenerated : 10/5/2018 12:08:58 PM
EntryType     : Warning
Message       : Type: Microsoft.Dynamics.Nav.Types.NavServerNotFoundException
The only thing that I have been able to figure out, is that it doesn't start the BC Server. It fails on loading the license, but because the service isn't running.
I first had this issue a couple of months ago. Here I were able to "fix" it, by lowering the memory to 4GB. Tried to lower to 3GB, but the same issue.
The thing is that it works with the RTM, but not with the insider builds.
Did anyone see this issue or got a clue what it could be?
Parents Reply Children
No Data
Related
Recommended
