When uploading files to NAV Server: The specified network name is no longer available.
 A call to System.IO.Copy field with this message: The specified network name is no longer available.
I Have checked the network , its working fine and it is the same. Did not understand
why out of the blue moon this issue has arose!
Parents Reply
  • As both and @RockWithNav says, it is a  folder access issue. The problem usually happens because when NAV was installed the SETUP.EXE file was not executed as Run As Administrator.
    Try changing the folderpermission for the folder:
    C:\ProgramData\Microsoft\Microsoft Dynamics NAV\110\Server\MicrosoftDynamicsNavServer$DynamicsNAV110\temp
    But again, it would still be nice to know. What Version of NAV? Build Nol? Standard-code or not?
Children
No Data
Related
Recommended
