Business Central Docker Container Gone After Restart Host
Hi Everybody,
I'm using docker container to do business central development and i'm using an Azure VM Win10 Pro as Host with Docker installed.
The problem is the container sometimes gone when the machine was turned off. Anyone having the same issue?
FYI I use auto shutdown on the VM, could that be have something to do with it?
Additional information:
So basically i did this: docs.microsoft.com/.../devenv-get-started-container-sandbox
on an Azure VM running on Windows 10.
The problem is sometimes after rebooting the VM, the container is gone so i had to recreate the container (all the steps done is based on the article above).
Riksa
Parents Reply Children
No Data
Related
Recommended
