Adjust Cost - Item entries report 795
The report Adjust Cost - Item Entries gives me a fatal error during the report runs.
A fatal error occurred. The connection to SQL server cannot be established or is no longer usable. This can be caused by one of the following reasons:
* The server has been shut down manually or because of an error.
* The SQL server connection settings are not correct
* A network failure has occurred.
* A hardware failure has occurred on the server or on your computer.
Try again later or contact your system administrator.
This error message shows up for one company and not in other companies in same database.
I looked on internet to find an answer for this topic but couldn't find it.
Does anyone has an experience in this error?
It happens in Dynamics NAV version 7.1.3 build 7.10.45478
Related
Recommended
