While Installing NAV 2016 Web Server Component Not Install It gives Fatal Error.
Web Server Components
Fatal error during installation.
Please Give Solution For This Thanks In Advance.
Log File:-
=== Logging started: 2017/11/13 13:00:43 ===
Executable: F:\Nav Patches\CU 24 NAV 2016 IN\NAV.9.0.49326.IN.DVD\setup.exe v9.0.49326.0
Computer : KALYAN
--- logging level: standard ---
RegistrySearch: Id = 'SqlServerInstalled', checking registry key existence.
Id = 'SqlServerInstalled', Key = 'SYSTEM\CurrentControlSet\Services\MSSQL$NAVDEMO', Exists = '1'
RegistrySearch: Id = 'SqlNCLIInstalled', checking registry key existence.
Id = 'SqlNCLIInstalled', Key = 'SOFTWARE\Microsoft\SQLNCLI11', Exists = '1'
RegistrySearch: Id = 'DotNetFx45Release', searching for registry key value.
Id = 'DotNetFx45Release', Key = 'SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full', Value = '460805'
RegistrySearch: Id = 'VstoInstalled', searching for registry key value.
Id = 'VstoInstalled', Key = 'SOFTWARE\Microsoft\VSTO Runtime Setup\v4R', Value = '1'
RegistrySearch: Id = 'PowerShell30Installed', searching for registry key value.
Id = 'PowerShell30Installed', Key = 'SOFTWARE\Microsoft\PowerShell\3\PowerShellEngine', Value = '4.0'
RegistrySearch: Id = 'WindowsSearchInstalled', checking registry key existence.
Id = 'WindowsSearchInstalled', Key = 'SYSTEM\CurrentControlSet\Services\WSearch', Exists = '1'
RegistrySearch: Id = 'Excel14Installedx86', searching for registry key value.
Id = 'Excel14Installedx86', Key = 'SOFTWARE\Microsoft\Office\14.0\Excel\InstallRoot', Value = 'C:\Program Files (x86)\Microsoft Office\Office14\'
RegistrySearch: Id = 'Excel14Installedx64', searching for registry key value.
Id = 'Excel14Installedx64', Registry key not found. Key = 'SOFTWARE\Microsoft\Office\14.0\Excel\InstallRoot'
RegistrySearch: Id = 'Outlook', checking registry key existence.
Id = 'Outlook', Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\OUTLOOK.EXE', Exists = '1'
RegistrySearch: Id = 'Outlook15', checking registry key existence.
Id = 'Outlook15', Key = 'Software\Microsoft\Office\15.0\Outlook', Exists = '0'
RegistrySearch: Id = 'VCPPSpLevel', searching for registry key value.
Id = 'VCPPSpLevel', Key = 'SOFTWARE\Microsoft\DevDiv\VC\Servicing\12.0', Value = '0'
RegistrySearch: Id = 'VCPPInstalled', checking registry key existence.
Id = 'VCPPInstalled', Key = 'SOFTWARE\Microsoft\DevDiv\VC\Servicing\12.0', Exists = '1'
RegistrySearch: Id = 'VCPP64Installed', checking registry key existence.
Id = 'VCPP64Installed', Key = 'SOFTWARE\Microsoft\DevDiv\VC\Servicing\12.0', Exists = '1'
RegistrySearch: Id = 'IISInstalled', checking registry key existence.
Id = 'IISInstalled', Key = 'SOFTWARE\Microsoft\InetStp', Exists = '1'
RegistrySearch: Id = 'IISWinAuthInstalled', searching for registry key value.
Id = 'IISWinAuthInstalled', Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = '1'
RegistrySearch: Id = 'IISASPNETInstalled', searching for registry key value.
Id = 'IISASPNETInstalled', Registry value not found. Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = 'ASPNET'
RegistrySearch: Id = 'IISASPNET45Installed', searching for registry key value.
Id = 'IISASPNET45Installed', Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = '1'
RegistrySearch: Id = 'IISNETFXInstalled', searching for registry key value.
Id = 'IISNETFXInstalled', Registry value not found. Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = 'NetFxExtensibility'
RegistrySearch: Id = 'IISNETFX45Installed', searching for registry key value.
Id = 'IISNETFX45Installed', Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = '1'
RegistrySearch: Id = 'IISISAPEXInstalled', searching for registry key value.
Id = 'IISISAPEXInstalled', Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = '1'
RegistrySearch: Id = 'HttpActivationInstalled', checking registry key existence.
Id = 'HttpActivationInstalled', Key = 'SYSTEM\CurrentControlSet\Services\WAS', Exists = '1'
RegistrySearch: Id = 'IISISAPIFIInstalled', searching for registry key value.
Id = 'IISISAPIFIInstalled', Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = '1'
RegistrySearch: Id = 'IISREQSTFIInstalled', searching for registry key value.
Id = 'IISREQSTFIInstalled', Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = '1'
RegistrySearch: Id = 'IISSTATICInstalled', searching for registry key value.
Id = 'IISSTATICInstalled', Key = 'SOFTWARE\Microsoft\InetStp\Components', Value = '1'
RegistrySearch: Id = 'WebComponentsPrerequisitesInstalled', searching for registry key value.
Id = 'WebComponentsPrerequisitesInstalled', Key = 'SOFTWARE\Microsoft\Microsoft Dynamics NAV\90\Web Components Prerequisites', Value = '1'
RegistrySearch: Id = 'IdentityFoundationInstalled', checking registry key existence.
Id = 'IdentityFoundationInstalled', Key = 'SOFTWARE\Microsoft\Windows Identity Foundation\Setup\v3.5', Exists = '1'
Configuring package. Id = 'ARP'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.df.log
Done configuring package. Id = 'ARP' ReturnCode = 0
Configuring package. Id = 'IISURLRewite'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e0.log
Done configuring package. Id = 'IISURLRewite' ReturnCode = 0
Configuring package. Id = 'ADCS_Id'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e1.log
Done configuring package. Id = 'ADCS_Id' ReturnCode = 0
Configuring package. Id = 'RoleTailoredClient'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e2.log
Done configuring package. Id = 'RoleTailoredClient' ReturnCode = 0
Configuring package. Id = 'SQLDemoDatabase'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e3.log
Done configuring package. Id = 'SQLDemoDatabase' ReturnCode = 0
Configuring package. Id = 'ServiceTier'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e4.log
Done configuring package. Id = 'ServiceTier' ReturnCode = 0
Configuring package. Id = 'ClickOnceInstallerTools'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e5.log
Done configuring package. Id = 'ClickOnceInstallerTools' ReturnCode = 0
Configuring package. Id = 'OutlookAddIn'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e6.log
Done configuring package. Id = 'OutlookAddIn' ReturnCode = 0
Configuring package. Id = 'WebClient'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e7.log
Done configuring package. Id = 'WebClient' ReturnCode = 1603
Configuring package. Id = 'RoleTailoredClient_IN'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e8.log
Done configuring package. Id = 'RoleTailoredClient_IN' ReturnCode = 0
Configuring package. Id = 'ServiceTier_IN'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.e9.log
Done configuring package. Id = 'ServiceTier_IN' ReturnCode = 0
Configuring package. Id = 'OutlookAddIn_IN'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.ea.log
Done configuring package. Id = 'OutlookAddIn_IN' ReturnCode = 0
Configuring package. Id = 'WebClient_IN'
MSI log file set to: C:\Users\Admin\AppData\Local\Temp\setup.wix.msi.eb.log
Done configuring package. Id = 'WebClient_IN' ReturnCode = 0
SUCCESS: Package Microsoft Dynamics NAV Setup Components executed sucessfully.
SUCCESS: Package Microsoft IIS URL Rewrite Module (64-bit) executed sucessfully.
SUCCESS: Package Automated Data Capture System for Microsoft Dynamics NAV executed sucessfully.
SUCCESS: Package Microsoft Dynamics NAV Client Components executed sucessfully.
SUCCESS: Package Cronus Sample Database for Microsoft Dynamics NAV executed sucessfully.
SUCCESS: Package Microsoft Dynamics NAV Server Components executed sucessfully.
SUCCESS: Package ClickOnce Installer Tools executed sucessfully.
SUCCESS: Package Microsoft Dynamics NAV Outlook Add-In executed sucessfully.
ERROR: Package Web Server Components failed with error. See detailed message above.
SUCCESS: Package Language Module (en-IN) for Microsoft Dynamics NAV Windows Client executed sucessfully.
SUCCESS: Package Language Module (en-IN) for Microsoft Dynamics NAV Server executed sucessfully.
SUCCESS: Package Language Module (en-IN) for Microsoft Dynamics NAV Outlook Add-In executed sucessfully.
SUCCESS: Package Language Module (en-IN) for Microsoft Dynamics NAV Web Server Components executed sucessfully.
=== Logging stopped: 2017/11/13 13:10:17 ===
Related
Recommended
