Which Navision code is posting sale & purchase values in GLs of GL Entry Table
Hello.
I am searching code in code unit 12, 21, 22 & 90 that is responsible for posting values in GL A/c No. in GL table at the time of Purchase and sale and i found function like InsertGLEntry() that is posting values from GLEntryTmp table type variable and this variable getting values from GLEntry table type variable and GLEntry variable getting values from GenJnlLine table type variable but unable to find actual codes that converting and assigning sale/purchase values according to GL Account nos.
So pls tell me where i can find it and share same codes ...
Thanks.
  • You will have to create your own function to write it to Gen. Journal line table and post it right from this function, do not use standard NAV function as you don't know where all it will be called from and keep in mind some functions use publisher and subscriber and by calling insertglentry function you might be posting additional line, if I were you I would create my own function and call this function to post any additional entries into G/L entry table.
  • If you are using NAV 2016 then you would go to codeunit 90 and search for
    // Balancing account
    IF "Bal. Account No." <> '' THEN BEGIN
    IF GUIALLOWED THEN
    Right after this lines of code is executed, you will call your function, first create a function and you can use the same code as show in the above //Balancing account code. Make sure are putting a condition as to when this code should be called, I am not sure what you are trying to accomplish in purchase side but put a condition otherwise for every line in the purchase it will create a G/L account, also make sure you have the Account no. and Bal. Account no. populated, otherwise your posting will fail. In purchase & receivable setup create a field for G/L account no. and Bal. Account no. and populate them and use these fields in the posting routine in your function to post the additional line while posting. Also In the G/L entry table I would create a new boolean field to identify the transaction which would let you know that you posted this transaction.
  • PostExcise_Function.txt
    PostExcise(GenJnlLine : Record "Gen. Journal Line")
    WITH GenJnlLine DO BEGIN
      IF "Excise Amount" <> 0 THEN BEGIN
        IF "Gen. Posting Type" =  "Gen. Posting Type"::Purchase THEN BEGIN
          ExcisePostingSetup.SETRANGE("Excise Bus. Posting Group","Excise Bus. Posting Group");
          ExcisePostingSetup.SETRANGE("Excise Prod. Posting Group","Excise Prod. Posting Group");
          ExcisePostingSetup.SETRANGE("From Date",0D,GenJnlLine."Posting Date");
         IF ExcisePostingSetup.FIND('+') THEN
            IF (("Account Type" = "Account Type"::"Fixed Asset") OR
            (("Account Type" = "Account Type"::"G/L Account") AND ("Capital Item")))
            THEN BEGIN
               ExcisePostingSetup.TESTFIELD("Cenvat Cr. Receivable Account");
               InitGLEntry(ExcisePostingSetup."Cenvat Cr. Receivable Account",
               ROUND((("Excise Amount" - "ADC VAT Amount")/2) + "ADC VAT Amount"),
               ROUND((("Source Curr. Excise Amount" - "Source Curr. ADC VAT Amount")/2) + "Source Curr. ADC VAT Amount"),
               TRUE,"System-Created Entry");
               InsertGLEntry(TRUE);
               InsertExciseforCapitalItems(GenJnlLine,ExcisePostingSetup."Cenvat Cr. Receivable Account",FALSE);
               ExcisePostingSetup.TESTFIELD("Cenvat Cr. (Deferred) Account");
               InitGLEntry(ExcisePostingSetup."Cenvat Cr. (Deferred) Account",
               ("Excise Amount" - ROUND((("Excise Amount"-"ADC VAT Amount")/ 2) + "ADC VAT Amount")),
               ("Source Curr. Excise Amount" - ROUND((("Source Curr. Excise Amount" - "Source Curr. ADC VAT Amount")/2) +
                "Source Curr. ADC VAT Amount")), TRUE,"System-Created Entry");
               InsertExciseforCapitalItems(GenJnlLine,ExcisePostingSetup."Cenvat Cr. (Deferred) Account",TRUE);
           END ELSE BEGIN
             IF NOT Trading THEN BEGIN
                 InitGLEntry(ExcisePostingSetup."Cenvat Cr. Receivable Account","Excise Amount","Source Curr. Excise Amount",
                 InsertExcise(GenJnlLine,ExcisePostingSetup."Cenvat Cr. Receivable Account");
             END ELSE BEGIN
               IF "Sales Return Order" THEN BEGIN
                  ExcisePostingSetup.TESTFIELD("Cenvat Transfered(Trading)");
                  InitGLEntry(ExcisePostingSetup."Cenvat Transfered(Trading)","Excise Amount","Source Curr. Excise Amount",
               END ELSE BEGIN
                 ExcisePostingSetup.TESTFIELD("Cenvat Cr. Receivable(Trading)");
                 InitGLEntry(ExcisePostingSetup."Cenvat Cr. Receivable(Trading)","Excise Amount" ,
                 "Source Curr. Excise Amount",TRUE,"System-Created Entry"); //FTS_AS_001 Modify Excise Amt
                 //FTS_AS_001
                IF "ADC VAT Amount" <> 0 THEN BEGIN
                   InitGLEntry(ExcisePostingSetup."ADC VAT Account","ADC VAT Amount"
                   +"ADC VAT AmountClained"
                END;
               //FTS_AS_001
              END;
             //InsertGLEntry(TRUE);//FTS_AS_01
             InsertExcise(GenJnlLine,ExcisePostingSetup."Cenvat Cr. Receivable(Trading)");//Sandeep
           END;
       END;
     END;
        IF "Gen. Posting Type" =  "Gen. Posting Type"::Sale THEN BEGIN
          IF ExcisePostingSetup.FIND('+') THEN BEGIN
             IF "Document Type" = "Document Type" ::"Credit Memo" THEN BEGIN
               IF ("Account Type" = "Account Type"::"Fixed Asset") OR (("Account Type" = "Account Type"::"G/L Account") AND
               ("Capital Item"))
               THEN BEGIN
                 ExcisePostingSetup.TESTFIELD("Excise Payable Account");
                 InitGLEntry(ExcisePostingSetup."Excise Payable Account",
                 InsertExciseforCapitalItems(GenJnlLine,ExcisePostingSetup."Excise Payable Account",FALSE);
              END ELSE BEGIN
                    InitGLEntry(ExcisePostingSetup."Excise Payable Account","Excise Amount","Source Curr. Excise Amount",
                    InsertExcise(GenJnlLine,ExcisePostingSetup."Excise Payable Account");
                END ELSE BEGIN
                  InsertExcise(GenJnlLine,ExcisePostingSetup."Cenvat Transfered(Trading)");
                END;
              END;
           END ELSE BEGIN
              END ELSE BEGIN
                 //FTS_AS Code added to Create GL/Entry for "ADC VAT AMOUNT"
                 InitGLEntry(ExcisePostingSetup."ADC VAT Account",-(ABS(ROUND("ADC VAT Amount")))
                 +ABS(ROUND("ADC VAT AmountClained")),"Source Curr. Excise Amount",
                //RIL_AS
                {IF GenJnlLine."ADC VAT AmountClained" <> 0 THEN BEGIN
                InitGLEntry(ExcisePostingSetup."ADC Claim A/c","ADC VAT AmountClained","Source Curr. Excise Amount",
                END; }
              //RIL_AS
              IF GenJnlLine."SED PASS"  THEN    BEGIN
                InitGLEntry(ExcisePostingSetup."Custom Duty Account",+(ABS((ROUND("ADC VAT Amount")))
                +ABS(ROUND("ADC VAT AmountClained"))),"Source Curr. Excise Amount",
                END
             ELSE
             BEGIN
                 {InitGLEntry(ExcisePostingSetup."ADC Refund Due",-(ROUND("ADC VAT Amount")+
               TRUE,"System-Created Entry");}
               //RIL_AS
                 InitGLEntry(ExcisePostingSetup."ADC Claim A/c",+(ABS(ROUND("ADC VAT AmountClained"))),"Source Curr. Excise Amount",
                 {InitGLEntry(ExcisePostingSetup."ADC Lapse A/c",-((ROUND("ADC VAT Amount"))),"Source Curr. Excise Amount",
                 InsertGLEntry(TRUE); }
              END;
              InitGLEntry(ExcisePostingSetup."ADC Refund Due",+((ABS(ROUND("ADC VAT Amount")))),"Source Curr. Excise Amount",
              //RIL_AS
              END;
    END;
    END;
    END;
    END;
    END
    //FTS_AS Code added to Create GL/Entry for "ADC VAT AMOUNT", Even Excise is not applicable.
    ELSE
    BEGIN
        ExPostingGrp.SETRANGE("Excise Bus. Posting Group","Excise Bus. Posting Group");
        ExPostingGrp.SETRANGE("Excise Prod. Posting Group","Excise Prod. Posting Group");
        ExPostingGrp.SETRANGE("From Date",0D,GenJnlLine."Posting Date");
        IF ExPostingGrp.FIND('-') THEN
          ExPostingGrp.TESTFIELD("ADC VAT Account");
          ExPostingGrp.TESTFIELD("ADC Refund Due");
          ExPostingGrp.TESTFIELD("ADC Claim A/c");
          ExPostingGrp.TESTFIELD("Custom Duty Account");
          InitGLEntry(ExPostingGrp."ADC VAT Account",
          -ABS(ABS(ROUND("ADC VAT Amount"))+ABS(ROUND("ADC VAT AmountClained")))
          ELSE
          InitGLEntry(ExPostingGrp."ADC VAT Account",-ABS(ABS(ROUND("ADC VAT Amount")
    //RIL_AS
           InitGLEntry(ExPostingGrp."Custom Duty Account",ABS(ROUND("ADC VAT Amount")),"Source Curr. Excise Amount",
       END
       ELSE
          {InitGLEntry(ExPostingGrp."ADC Refund Due",+ROUND("ADC VAT Amount") +
          ROUND("ADC VAT AmountClained"),"Source Curr. Excise Amount",
         BEGIN
             InitGLEntry(ExPostingGrp."ADC Claim A/c",+(ROUND("ADC VAT AmountClained")),"Source Curr. Excise Amount",
          { InitGLEntry(ExPostingGrp."ADC Lapse A/c",+(ROUND("ADC VAT Amount")
           InsertGLEntry(TRUE);}
         END;
        //ELSE BEGIN
           +ABS((ROUND("ADC VAT Amount")) ),"Source Curr. Excise Amount",
          InsertGLEntry(TRUE);  END;
         //END;
    END;
    END;
    Thanx for your reply and explanation
    My purpose is posting of "Purchase Line"."Column Value" and "Sale Line"."Column Value" to G/L entry table against newly created GL.
    So i created new column in "Excise Posting Setup" table to mention new GL No. and trying to create new below function as created in above attachment for "ADC VAT Account".
           THEN BEGIN
              ROUND((("Excise Amount" - "BED Amount")/2) + "BED Amount"),
              ROUND((("Source Curr. Excise Amount" - "Source Curr. BED Amount")/2) + "Source Curr. BED Amount"),
              ("Excise Amount" - ROUND((("Excise Amount"-"BED Amount")/ 2) + "BED Amount")),
              ("Source Curr. Excise Amount" - ROUND((("Source Curr. Excise Amount" - "Source Curr. BED Amount")/2) +
               "Source Curr. BED Amount")), TRUE,"System-Created Entry");
                 END ELSE
              IF "BED Amount" <> 0 THEN BEGIN
                  InitGLEntry(ExcisePostingSetup."BED Account","BED Amount"
                END;  END;
       IF ExPostingGrp.FIND('-') THEN BEGIN
         ExPostingGrp.TESTFIELD("BED Account");
          IF GenJnlLine."BED Amount" <> 0 THEN BEGIN
          InitGLEntry(ExPostingGrp."BED Account",ABS(ROUND("BED Amount")),"Source Curr. Excise Amount",
          END
          END;        END;END;   END;
Related
Recommended
