There is no Currency Exchange Rate within the filter
hi there guys
A user was trying to post revaluation to an item and encountered the following error
"There is no Currency Exchange Rate within the filter.
Filters: Currency Code: USD, Starting Date: ''..12/31/14"
Note.:We don't use multi-currency transaction only local currency
  • Hey guys
    I solved my issue and here is the solution if it might help someone like me
    Issue surfaced while posting revaluation journal as i told you earlier
    Cause : I checked the exchange rate for USD and starting date has been set to 2015 but the item being revalued might be involved during the data migration that's my hesitation.
    Solution: i just changed the USD exchange rate starting date to 2014
Related
Recommended
