Cancel the Creation Process when try to create/open Word Template
I have the issue described here
https://dynamicsuser.net/nav/f/technical/33092/cannot-create-word-template-attachment-you-have-canceled-the-create-process#
with NAV 2016 & Word 2013. When I try to Create/open a template Word pops up in the Task bar and closes within a second.
NAV says :"You have canceled the create process."
Error comes From T5103:
CreateAttachment()
  IF "Attachment No." <> 0 THEN BEGIN
    IF Attachment.GET("Attachment No.") THEN
      Attachment.TESTFIELD("Read Only",FALSE);
    IF NOT CONFIRM(Text001,FALSE) THEN
      EXIT;
  END;
  NewAttachNo := WordManagement.CreateWordAttachment("Interaction Template Code" + ' ' + Description,"Language Code");
  IF NewAttachNo <> 0 THEN BEGIN
      RemoveAttachment(FALSE);
    "Attachment No." := NewAttachNo;
    IF InteractTmplLanguage.GET("Interaction Template Code","Language Code") THEN
      MODIFY
    ELSE
      INSERT;
  END ELSE
    ERROR(Text000);
It seems, that NAV can't create the Word File.. Anybody knows why ?
Thank you
Related
Recommended
