GDT Where used PLUS -Professional code analyzing tool
GDT Where Used PLUS is a professional code analyzing tool with limited version management capabilities.
  • Works with NAV 5, NAV2009, NAV2013, NAV2015, NAV2016
Features:
- shows where Objects, Functions and Fields are used, like its predecessor GDT Where Used.
- can be used with multiple users on the network with the same data.
- supports multiple projects (In this context, project means the objects of a customer database.)
- supports multiple versions. You can import as many versions to a project as you like.
- Object compare. Choose an object and see the differences in a text comparison tool of your choice.
- CodeGuard. Analyze two versions. CodeGuard will check all objects and verify based on the source comments that your code is preserved.
(In case someone doesn't merge objects correctly or you simply want to see all changes made to keep up to date.)
- Syntax coloring
- Function View. You can expand a function of another object directly in the code viewer.
Implementation:
GDT Where Used PLUS is an external program. Objects can be imported through Finsql form Nav or simply as object text import.
There is no link back, your objects in Nav will never be touched.
Performance:
Selecting projects, versions as well as where used functionality cost no time.
GDT Where Used PLUS needs time once to analyze objects (usually ~1 min) via text import. Additional time is required if you use Finsql.
Object compare function needs time to start the text comparison tool.
The time CodeGuard needs depends on the number of changed objects.
www.crocodilebytes.com
Related
Recommended
