This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
NS Outlook Synchronization Handler for Outlook 2010
it seems the latest available version of the OLHandler.dll is not compatible with Outlook 2010 (at least the 64bit version i have installed). The one i currently have installed is the one from Platform update 2 for NAV5 SP1, it seems to be the same as the one in the install for NAV 2009 SP1.
Here is the file information:
NS Outlook Synchronization Handler    {03BC4F50-2ABB-48B3-B2A6-3F08EB1D013E}    1.7    OLHandler.dll
Anyone has a newer version? And can anyone confirm if this works with the 32 bit version of Outlook 2010?
  • Based on most blogs and also Erik's recommendations, it seems that unless you really have special reasons for needing the 64bit version, you should stay on the 32 bit version. So that is what im doing now, uninstalling, installing..... sigh!
Related
Recommended
