how to kill users in Navision those who are ideal for long time
Can any one help us. Is there any query for SQL which can clear users automatically every 5 minutes.
regard
  • Read following:
    http://www.mibuso.com/howtoinfo.asp?FileID=18
  • Create a codeunit or report to kill idle users.
    Then use the job scheduler to run that report every X number of minutes.
  • watch at this solution from Steve Jones, http://www.sqlservercentral.com/
    "Ever wanted to get rid of users who are sitting idle for long periods of time?
    Here's a script that removes spids idle for a variable period of time."
    SQL SCRIPT
    if object_Id( 'dbspKillIdleSpids') Is Not Null
     drop procedure dbspKillIdleSpids
    go
    CREATE procedure dbspKillIdleSpids
     @sec int = Null
    as
    Description: kills connections that have been
    inactive for @sec seconds.
    Usage: exec dbspKillIdleSpids <sec>
    Author: Steve Jones - www.dkranch.net
    Input Params:
    @sec  int. defaults to  Null, # seconds for connection to be
     idle to kill it.
    Output Params:
    Return: 0, no error. Raises error if no parameters sent in.
    Results:
    Locals:
    Modifications:
    declare @err int,
      @spid int,
      @cmd char( 100)
    if @sec Is Null
     begin
      raiserror( 'Usage:exec dbspKillIdleSpids <sec>', 12, 1)
      return -1
     end
    declare u_curs scroll insensitive cursor for
     select s.spid
      from master..sysprocesses s
      where ( datediff( ss, s.last_batch, getdate())) > @sec
    open u_curs
    fetch next from u_curs into @spid
    while @@fetch_status = 0
     begin
      select @cmd = 'kill ' + convert( char( 4), @spid)
      print @cmd
     end
    deallocate U_curs
    return
    GO
Related
Recommended
