NAV 2013 80437 CSIDE exam Lab files problem
I installed NAV 2013R2 demo and I have demo/dev license. I'm using training materials with lab files. All is good except I cannot import some lab files. That is most likely due to the Object ID range used in the lab files. It's numbered as 123456700, etc. For the text lab files I'm changing the Object ID and all is importing Ok but for the fob files I cannot do it. Any advice how I could handle it?
  • Here is an error message that I'm receiving trying to import files:
    I did also try the command line to import as "...\finsql.exe command=importobjects, file=..." there is no error but nothing was imported.
  • In reply to Alexander:
    I did what the error message said. I did get NAV 2013 (not R2) installation files that is lower version to 2013 R2 that I'm using. Then, I ran the finsql.exe from there, created a new db and imported all to this db first. Then, I was able to import fob files into 2013 R2 db.
    Forgotten to mention that I got the help on this from mibuso.
Related
