dimensions
Your client uses a dimension named ITEM CLASS with different dimension values to define different types of items on sales postings.
 You need to modify the dimension settings so that sales-related ledger entries contain information on the type of item sold.
Which two actions should you perform? (Each correct answer presents part of the solution. Choose two.)
A. Add a unique ITEM CLASS dimension value code to all individual item category cards.
B. Set the Dimension Value Posting field for the ITEM CLASS dimension code to Code Mandatory for the sales-related G/L account cards.
C. Add a unique ITEM CLASS dimension value code to all individual item cards.
D. Set the Dimension Value Posting field for the ITEM CLASS dimension code to Same Code for the sales-related G/L account cards
Please give reasons for your answers to help me understand..
Related
