MB7-840
Hi to all,
i have also some other questions
1. suppose while running the codeunit u got the run time error when u review the code u found out the string is overflow by which function u can resolve the problem(select 2 options)
A. SELECTSTR
B. MAXSTRLEN
C. STRPOS
D. COPYSTR
2.if u created ane array with 10 index having variable name SalesPrice now u want to delete the 4th and 7th index's data which syntax u will use?
A. SalesPrice[4] := 0;
    SalesPrice[7] := 0;
 B. SalesPrice[4,7] := 0;
C. CLEAR(SalesPrice[4,7] = 0);
didnt remember the last option
Thanks.
  • 1. B&D
    2. A
  • In reply to Mohana:
    Jay I think you need to read technical Manual of Navision as well as try some questions in Navision by writing given code in question You will surely get all answers ..
    All the BestSmile
  • In reply to Amol:
    Thank u for the advice.
    I have thoroughly  read  the book called Programming Microsoft Dynamics NAV and also done the practice in NAV Classic.But some of the topics  haven't covered in this book special codeunits,Menusuites.so can u suggest me some materials that covered this topics.As u mentioned technical manual of Navision from where i can get this material.
  • In reply to Amol:
    Thanks a lot Mohana
Related
