Navision 3.53 - connecting via Netbios
PC connceted to netware 3.12 contains database. New workstation with win98 with
microsofts bindery-client want to connect,
but responds back it cannot connect without
netbios (error 20 I think)
Any place to read about connecting rules/problems, or any help at all ???.
Thanks in advance
  • It's a long time ago, but from the things i remember:
    Did you try to start with parameter NETTYPE=TCP (or NETTYPE=NETB).
    To view all possible parameters start your client with "NAVI.EXE ?".
    Hope this is what you are looking for.
    Willy
    Edited by - wex on 2001 Aug 09 08:28:04
  • Also the NetBios needs to be the default nettype.
    (Start -> Settings -> Control Panel -> Network -> Select the NetBios protocol -> Proberties -> Advanced Tab -> Make sure Default is checked.
    I would acturally suggest that you delete the TCP/IP protocol. if You still are having the problem.
    Somehow if that were installed. it seems like Microsoft were "Helping" people to select TCP/IP wether they want it or not.
    hmm - Can't help getting a little sentimeltal when working on the good old blue navision ;-)
    /Henrik
  • Also - When running Windows 98 - You ought to run NAVIN.EXE!
    _________________
    Kind Regards --
    Henrik Helgesen, moderator <a href="http://www.navision.net/forum/forum.asp?FORUM_ID=12&CAT_ID=4&Forum_Title=Danish" target="New">Danish</a>
Related
Recommended
