Temporary Record Copying
Hello Community,
i'm kind of confused.
I got an example i would like to get solved.
If you would perform calculations on user selection in Page 981 (Payment Registration Buffer) what would be the correct way to do so?
I tried to copy the Tab981 (Temporary) into another Table of the same specification, but I can not manage it, because if i would loop through the original record to perform a newRec := Rec and newRec.Insert -> everything is getting messed up. Its bad practice to loop through the displayed record and it gives you weird results.
How can i copy the record so, i can perform all my calculations, while the original record is untouched?
Related
Recommended
