Workflow check customize in nav 2018
Hi Team,
My client is requesting for workflow check customize based on workflow user group, which contains the following fields: User ID, Full Name, Role (Sequence No.) and Dept Code (Dimension Value) whereby He filter by Dept Code to get the current workflow user group. Its possible yes or no. If yes I need your guide.
Regards.
Related
Recommended
