Customized reversed code in Dynamics NAV 2018
Hi Team,
I wrote the below code for reversal which is working fine but after the reverse action it display this "The journal lines were successfully posted. You are now in the TB-0000029 journal." I want it to display "The journal lines were successfully reversed." I also wanted to check the Reversed in the G/L entry.
WITH TBill DO BEGIN
IF CONFIRM(Text001+' '+"No."+' ?') = TRUE THEN BEGIN
  IF TBill.Reversed THEN
    ERROR(Text002,"PFA Name");
  CMSetup.GET();
  //Delete Lines Present on the General Journal Line
  GenJnLine.RESET;
  GenJnLine.SETRANGE(GenJnLine."Journal Template Name",CMSetup."Payment Voucher Template");
  GenJnLine.SETRANGE(GenJnLine."Journal Batch Name","No.");
  GenJnLine.DELETEALL;
  Batch.INIT;
  IF CMSetup.GET() THEN
    Batch."Journal Template Name" := CMSetup."Payment Voucher Template";
  Batch.Name := "No.";
  IF NOT Batch.GET(Batch."Journal Template Name",Batch.Name) THEN
    Batch.INSERT;
  Lines.RESET;
  Lines.SETRANGE("No.","No.");
  IF Lines.FINDSET THEN BEGIN REPEAT //Name: IB, Date:04/09/2019
  instrumentNo := COPYSTR(Lines."Instrument No.",1,20);
    LineNo := LineNo + 1000;
    //Post bank Entries
    GenJnLine.INIT;
    GenJnLine."Journal Template Name" := CMSetup."Payment Voucher Template";
    GenJnLine."Journal Batch Name" := "No.";
    GenJnLine."Line No." := LineNo;
    GenJnLine."Account Type" := GenJnLine."Account Type"::"G/L Account";
    IF InvestmentAccountSetup.GET(PFA,Fund,"Type of Investment") THEN
      GenJnLine."Account No." := InvestmentAccountSetup."Asset Account";
    GenJnLine."Posting Date" := Lines."Settlement Date";
    GenJnLine."Document No." := instrumentNo;
    GenJnLine.Description := Lines."Bill Series Code";
    GenJnLine.Amount := -Lines.Consideration;
    GenJnLine.VALIDATE(GenJnLine.Amount);
    GenJnLine."Bal. Account Type" := GenJnLine."Bal. Account Type"::"Bank Account";
    GenJnLine.VALIDATE("Bal. Account No.","Bank Account");
    GenJnLine."External Document No." := "No.";
    GenJnLine.VALIDATE(GenJnLine."Shortcut Dimension 1 Code",PFA);
    GenJnLine.VALIDATE(GenJnLine."Shortcut Dimension 2 Code",Fund);
    IF GenJnLine.Amount <> 0 THEN
       GenJnLine.INSERT;
    UNTIL Lines.NEXT = 0;
    END;
    CODEUNIT.RUN(CODEUNIT::"Gen. Jnl.-Post",GenJnLine); // This is what is doing it.
    GLEntry.RESET;
    GLEntry.SETRANGE(GLEntry."Journal Batch Name","No.");
    GLEntry.SETRANGE(GLEntry.Reversed,FALSE);
    IF GLEntry.FINDFIRST THEN BEGIN
      Lines.RESET;
        IF Lines."Transaction Type" = Lines."Transaction Type"::Buy THEN BEGIN
        //Ledger
        //Reverse Previous Values
        TBillLedger.RESET;
        TBillLedger.SETRANGE("Bill Series Code",Lines."Bill Series Code");
        TBillLedger.SETRANGE(PFA,PFA);
        TBillLedger.SETRANGE(Fund,Fund);
        TBillLedger.SETRANGE("Instrument No.",Lines."Instrument No.");
        IF TBillLedger.FINDSET THEN
          TBillLedger.MODIFYALL(Reversed,TRUE,TRUE);
        TBillLedgerOld.RESET;
        IF TBillLedgerOld.FINDLAST THEN
          EntryNo := TBillLedgerOld."Entry No" +1
        ELSE
          EntryNo := 1;
        TBillLedger.INIT;
        TBillLedger."Entry No" := EntryNo;
        TBillLedger.VALIDATE("Bill Series Code",Lines."Bill Series Code");
        TBillLedger.PFA := Lines.PFA;
        TBillLedger.Fund := Lines.Fund;
        TBillLedger.VALIDATE("Instrument No.",Lines."Instrument No.");
        TBillLedger."Transaction Type" := TBillLedger."Transaction Type"::Acquisition;
        TBillLedger.Consideration := -Lines.Consideration;
        TBillLedger."Face Value" := -Lines.Principal;
        TBillLedger."Discounted Value" := -Lines."Discounted Amount";
        TBillLedger."Trade Date" := Lines."Trade Date";
        TBillLedger.VALIDATE("Value Date",Lines."Trade Date");
        TBillLedger.Reversed := TRUE;
        TBillLedger."Reversed By" := USERID;
        TBillLedger."Reversed Date" := TODAY;
        TBillLedger.INSERT(TRUE);
        //TBill Investment
        //Delete Previous Values
        TBills.RESET;
        TBills.SETRANGE("Bill Series Code",Lines."Bill Series Code");
        TBills.SETRANGE(PFA,PFA);
        TBills.SETRANGE(Fund,Fund);
        TBills.SETRANGE("Transaction No.",Lines."Instrument No.");
        IF TBills.FINDSET THEN
          TBills.DELETEALL;
        END;
        COMMIT;
        END;
        Reversed := TRUE;
        MODIFY;
END;
END;
END;
//End
Thanks.
Related
Recommended
