Enabling Sales order and order credit limit approval workflows in parallel
Hello All
While Sales Order Approval Workflow is enabled and working fine in Dynamics NAV 2017, the client needed to enable Sales Order Credit Limit Approval Workflow.
while enabling the "Sales Order Credit Limit Approval Workflow" it showed the error below and it becomes clear that both workflows cannot work in parallel, is there any way or trick to get this accomplished?
one or more entry-point steps exist that use the same event on sales header table."You must specify unique event conditions on entry-point steps that use the same table.
Thanks in advance
Related
Recommended
