AN ERROR WAS RAISED BY METHOD RANGE
Good Mornig Fellow Geeks
My morning is being messep up by this error i get when run this code below actually the code is supposed to  populate data into my excel sheet but again i get this error i dont know what it means
IF exp THEN BEGIN
Sheets.Range('A'+myJ).Value:=FORMAT(Resource."No.");
Sheets.Range('B'+myJ).Value:=FORMAT(Resource.Name);
Sheets.Range('C'+myJ).Value:=FORMAT("Res. Ledger Entry".Description);
Sheets.Range('D'+myJ).Value:=FORMAT("Unit of Measure Code");
Sheets.Range('E'+myJ).Value:=FORMAT("Res. Ledger Entry".Quantity);
Sheets.Range('F'+myJ).Value:=FORMAT("Contract No");
myJ:=INCSTR(myJ);
END;
Related
Recommended
