This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
AX 2012 R2 CU 7 Released
CU7
  • Hi Kranthi,
    I got problem when update cu7 from cu6:
    The model contains a customization of a configuration key. The model cannot be imported because you can overlayer a configuration key from the patching layer only.
    Do you have any idea?
    Thanks for your help.
    Kind Regards,
Related
Recommended
