ModalPageHandler does not run as control add in is not instantiated
Hi I've the below [Modal Page Handler]
[ModalPageHandler]
    procedure SignaturePageHandler(var Signature: TestPage "Signature Pad")
    begin
        Signature.Clear.Invoke();
        Signature.Undo.Invoke();
        Signature."Save Signature".Invoke();
    end;
I get the error that "The control add-in on control SignaturePad on page Signature Pad has not been instantiated".
I'm using the control add in signature pad from this Github repository: https://github.com/madearipermadi/ALSignaturePad
The add in contains a "OnControlAddInReady" trigger but when I put a var boolean in the trigger, I cannot access it from a testpage.
Can anyone advise on what changes I need to make to ensure that I can check that the control add in is instantiated from the ModalPageHandler function?
FYI: the original Signature Pad page code is given below:
page 50130 "Signature Pad"
    PageType = Card;
    ApplicationArea = All;
    UsageCategory = Tasks;
    InsertAllowed = true;
    ModifyAllowed = true;
    DeleteAllowed = true;
    Editable = true;
    layout
        area(Content)
            group(Signature)
                usercontrol(SignaturePad; SignaturePad_Ctrl)
                    trigger OnControlAddInReady()
                    begin
                    end;
                    trigger AfterSaveSignature(Image: Text)
                    var
                        SalesShipmentHeader: record "Sales Shipment Header";
                        Base64Convert: Codeunit "Base64 Convert";
                        Outstream: OutStream;
                    begin
                        SalesShipmentHeader.Get(PostedShipmentNo);
                        SalesShipmentHeader."Signature Image".CreateOutStream(OutStream);
                        Base64Convert.FromBase64(Image.Remove(1, 22), Outstream);
                        SalesShipmentHeader.Modify();
                        Message('Image has been saved');
                    end;
    actions
        area(Navigation)
            action("Clear")
                trigger OnAction()
                begin
                    CurrPage.SignaturePad.ClearPad();
                end;
            action("Update Profile")
                trigger OnAction()
                var
                    UserPersonalizationRec: record "User Personalization";
                    ProfileRec: record "All Profile";
                    SessionSettingVar: SessionSettings;
                    ProfileScope: Option System,Tenant;
                begin
                    UserPersonalizationRec.SetRange("User ID", UserId);
                    if UserPersonalizationRec.FindFirst() then begin
                        UserPersonalizationRec."Profile ID" := 'NEWPROFILE';
                        UserPersonalizationRec.Modify();
                        ProfileRec.SetRange("Profile ID", UserPersonalizationRec."Profile ID");
                        ProfileRec.FindFirst();
                        SessionSettingVar.Init();
                        SessionSettingVar.Company := CompanyName;
                        SessionSettingVar.ProfileId := UserPersonalizationRec."Profile ID";
                        SessionSettingVar.ProfileAppId := ProfileRec."App ID";
                        SessionSettingVar.ProfileSystemScope := ProfileScope = ProfileScope::System;
                        SessionSettingVar.LanguageId := UserPersonalizationRec."Language ID";
                        SessionSettingVar.LocaleId := UserPersonalizationRec."Locale ID";
                        SessionSettingVar.TimeZone := UserPersonalizationRec."Time Zone";
                        SessionSettingVar.RequestSessionUpdate(true);
                    end;
                end;
            action("Undo")
                trigger OnAction()
                begin
                    CurrPage.SignaturePad.Undo();
                end;
            action("Save Signature")
                trigger OnAction()
                var
                    Image: Text;
                begin
                    CurrPage.SignaturePad.SaveSignature(Image);
                end;
    var
        PostedShipmentNo: Code[20];
    procedure SetPostedShipmentNo(pcodePostedShipmentNo: Code[20])
    begin
        PostedShipmentNo := pcodePostedShipmentNo;
    end;
Many thanks in advance
Related
Recommended
