Table relation with selected records only
I do have a field with table lookup in which it shows all the records of the lookup table. The lookup table has fields F1,F2,F3 and Active (boolean). What I want is to display is only the records where Fieldname Active is true.  Can this be achieved from Tablerelation where Clause?  If so how can it be done?
Thanks and Regards.
Related
Recommended
