Extension Publish Error failed with code UnprocessableEntity
Everything was working fine on Wednesday but when I try to publish and debug an extension from Visual Studio Code to the Cloud Sandbox this morning, it's failing with:-
The request for path /v2.0/sandbox/dev/apps?SchemaUpdateMode=synchronize&DependencyPublishingOption=default failed with code UnprocessableEntity. Reason: You do not have the following permissions on TableData Published Application: IndirectInsert.
I've tried various extensions and they're all failing, but were working on Wednesday. No changes in between?
Any thoughts?
Related
Recommended
