Selected / Marked records
In an AL Extension CodeUnit, how do you iterate through the records that a user has selected / marked / ticked on a list page using the 'Select More' functionality? For instance, is there an IsMarked / IsSelected / IsTicked property in a data-type somewhere? Or, can you pass in the already drilled-down list to the codeunit?
  • One method would be currpage.setselectionfilter described here: https://docs.microsoft.com/en-us/dynamics-nav/setselectionfilter-function
    you could then pass the record variable used for the selectionfilter into a codeunit for further processing. An example of it in action from standard BC:
    action(CreateJobJournalLines)
    ApplicationArea = Jobs;
    Caption = 'Create Job &Journal Lines';
    Image = PostOrder;
    Promoted = true;
    PromotedCategory = Process;
    PromotedIsBig = true;
    ToolTip = 'Use a batch job to help you create sales journal lines for the involved job planning lines.';
    trigger OnAction()
    var
    JobPlanningLine: Record "Job Planning Line";
    JobJnlLine: Record "Job Journal Line";
    JobTransferLine: Codeunit "Job Transfer Line";
    JobTransferJobPlanningLine: Page "Job Transfer Job Planning Line";
    begin
    if JobTransferJobPlanningLine.RunModal = ACTION::OK then begin
    JobPlanningLine.Copy(Rec);
    CurrPage.SetSelectionFilter(JobPlanningLine);
    if JobPlanningLine.FindSet then
    repeat
    JobTransferLine.FromPlanningLineToJnlLine(
    JobPlanningLine, JobTransferJobPlanningLine.GetPostingDate, JobTransferJobPlanningLine.GetJobJournalTemplateName,
    JobTransferJobPlanningLine.GetJobJournalBatchName, JobJnlLine);
    until JobPlanningLine.Next = 0;
    CurrPage.Update(false);
Related
Recommended
