Hello,
In the last few days I'm facing the following error while downloading symbols:
You can find below launch.json and app.json:
The weirdness is that it worked until yesterday.
Do you have any suggestion?
It may be a permission issue. Did you update your windows password since yesterday? If you do, then you need to manually update it.
Thanks fo the answer. The issue was in the service settings. Flag "Enabling loading application symbol references at server startup" was off.
