Hi Sir,
I have one issue regarding RDLC Reports , I import report fob in to database ,when it compile , it throw's below error
You need to figure out if the problem is in the code in the old database where you created the fob file (if you created it). Or if it is caused by the database you are importing it into.
Did you try to export the fob file and can you import it to a different database?
