Copy data from Temp Table
Hi there,
This should be quite easy but I'm having trouble in doing it.
I copied data to a Temp Table with a primary key and added Fields.
Now I want to transfer that data back to the original table since that data was lost in the upgrade.
I just want to transfer the fields with the same key number to the original table
    local procedure TempCustomer_DataCopy()
    var
        DestinyTable: Record Customer;
        OriginTable: Record "Customer Temp";
    begin
        With OriginTable do begin
            if FindSet() then
                repeat
                    DestinyTable.Init();
                    DestinyTable.Transferfields(originTable);
                    DestinyTable.Insert;
                until next = 0;
        end;
    end;
Related
Recommended
