Hi experts,
I'm using NAV 2015 and have created a purchase table with some purchase lines.
I need to make some code that do the same as what is done, when a user on a purchLine enters a number of SerialNo's and/or LotNo's in the menu "Item Tracking Lines". There is no records in "Reservation Entries".
I also don't have a salesLine. The purchLine is not created because of a salesLine. It is just created manually.
Can anybody please help me?
Best regards,
Morten
Are you trying to enter the Serial no. or Lot no. in the purchase line itself, that's what I assuming from your request, also you are aware that you can enter multiple seirlal. no. and lot no. for a given line hence how will that be handled. Also 'I also don't have a salesLine. The purchLine is not created because of a salesLine. It is just created manually, I jjust don't get this what exactly you are trying to do here. If you can be more specific with your request, I may be able to help you..
