Connecting to Azure File Share (Not Blob Storage) through AL Code
Is it possible to connect to Azure File Share through AL code and import data from a file on the file share into a journal in BC (Cloud Version)? I have tried to use the Rest APIs with no luck (https://docs.microsoft.com/en-us/rest/api/storageservices/file-service-rest-api). The particular issue I keep running into is authorization. I'm doing authorization with a Shared Key and following the authorization guidelines based on MS documentation (https://docs.microsoft.com/en-us/rest/api/storageservices/authorize-with-shared-key).
Does anyone any other solutions to automatically read a file and import the data into a BC journal with no user interaction?
Code sample:
trigger OnRun()
    var
        requestMethod: Text;
        request: HttpRequestMessage;
        RequestHeader: HttpHeaders;
        hhtpres: HttpResponseMessage;
        canonicalizedResource: Text;
        canonicalizedHeaders: Text;
        urlPath: Text;
        client: HttpClient;
        content: HttpContent;
        authorizationHeader: Text;
        stringToSign: Text;
        msVersion: Text;
        cha: Char;
        contenttype: Text;
        contentLength: Integer;
        SharedKey: Text;
        dateInRfc1123Format: Text;
        EncryptionManagement: Codeunit "Cryptography Management";
        uri: Text;
        fileName: Text;
    begin
        cha := 10;
        msVersion := '2019-12-12';
        SharedKey := '<SharedKey>';
        dateInRfc1123Format := GetUTCDateTimeText();
        requestMethod := 'GET';
        fileName := 'abc.xlsm';
        urlPath := '<myshare>/<mydirectorypath>/<myfile>';
        CanonicalizedResource := StrSubstNo('/%1/%2', '<myaccount>', '<myshare>/<mydirectorypath>/<myfile>');
        canonicalizedHeaders := 'x-ms-date:' + dateInRfc1123Format + Format(cha) +
                                'x-ms-version:' + msVersion;
        stringToSign := (requestMethod + Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         Format(cha) +
                         canonicalizedHeaders + Format(cha) +
                         canonicalizedResource);
        authorizationHeader := 'SharedKey <myaccount>:' + EncryptionManagement.GenerateBase64KeyedHashAsBase64String(stringToSign, SharedKey, 2);
        uri := 'https://<myaccount>.file.core.windows.net/<myshare>/<mydirectorypath>/<myfile>';
        request.SetRequestUri(uri);
        request.Method := requestMethod;
        RequestHeader.Clear();
        request.GetHeaders(RequestHeader);
        RequestHeader.Add('Authorization', authorizationHeader);
        RequestHeader.Add('x-ms-date', dateInRfc1123Format);
        RequestHeader.Add('x-ms-version', msVersion);
        client.Send(request, hhtpres);
        if not hhtpres.IsSuccessStatusCode then
            Error(FORMAT(hhtpres.HttpStatusCode) + ': ' + hhtpres.ReasonPhrase)
        else
            Message(FORMAT(hhtpres.HttpStatusCode) + ': ' + hhtpres.ReasonPhrase);
    end;
Related
Recommended
