Hi,im upgrading from D365 V14 CU 04 to D365 V15 wave 2im getting the bellow error when I"Sync-NAVApp -ServerInstance BC150 -Name “Base Application” -Version 15.2.39040.0" Table Sales Price :: Unsupported field change. Field:Markup %; Change:Remove Table Sales Price :: Unsupported field change. Field:Profit %; Change:Remove Table Sales Price :: Unsupported field change. Field:Profit (LCY); Change:Remove Table Sales Price :: Unsupported field change. Field:Unit Price Including VAT; Change:Remove Table Purchase Price :: Unsupported field change. Field:Wholesale Price; Change:Remove Table Purchase Price :: Unsupported field change. Field:Discount %; Change:Remove Table Sales Price Worksheet :: Unsupported field change. Field:Markup %; Change:Remove Table Sales Price Worksheet :: Unsupported field change. Field:Profit %; Change:Remove Table Sales Price Worksheet :: Unsupported field change. Field:Profit (LCY); Change:Remove Table Sales Price Worksheet :: Unsupported field change. Field:New Unit Price Including VAT; Change:Remove At line:2 char:1 + Sync-NAVApp -ServerInstance BC150 -Name “Base Application” -Version 1 … + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : InvalidOperation: (:) [Sync-NAVApp], InvalidOperationException + FullyQualifiedErrorId : MicrosoftDynamicsNavServer$BC150/default,Microsoft.Dynamics.Nav.Apps.Management.Cmdlets.SyncNavApp
Any help would be great. Thanks in advance.
I hope you are using the Initial Release of Business Central 15 and not a cumulative Update of 15.
There is a compatibility Matrix when you upgrade from BC14 to BC15. You can read here more about the compatibility matrix.
https://saurav-nav.blogspot.com/2020/01/msdyn365bc-2019-wave-2-upgrade.html
I hope it helps.
Hi, thanks for your reply
I've read your article I upgrade from BC14 CU04 to BC14 CU07 and then I'm upgrading to BC 15 CU 02
but whenever I Sync-NAVApp -ServerInstance BC150 -Name "Base Application" -Version 15.2.39040.0
I'm getting the following error
"Sync-NAVApp : The following SQL error was unexpected:No item by the name of '"dbo"."COMP$Payment Terms$0"' could be found in the current database 'BC15', given that @itemtype was input as '(null)'.Caution: Changing any part of an object name could break scripts and stored procedures.Caution: Changing any part of an object name could break scripts and stored procedures.At line:2 char:1+ Sync-NAVApp -ServerInstance BC150 -Name "Base Application" -Version 1 ...+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : InvalidOperation: (:) [Sync-NAVApp], InvalidOperationException + FullyQualifiedErrorId : MicrosoftDynamicsNavServer$BC150/default,Microsoft.Dynamics.Nav.Apps.Management.Cmdlets.SyncNavApp"
any help would be appreciated.
Kindly note that the BC14 CU04 Database used to be LS retail database and when i upgraded to CU07 version and moved all the tables I've delete the LS objects from it.
