How right to select correct .Net components for HttpHeaders, HttpContent.. when do downgrade
Hi All.
Just decided to do downgrade a small solution and understood that I need your help, folks, with the right selection of DotNet components.
I read the article "JSON meets NAV" from Gunnar's Blog + CU 5459 "JSON Management" and can try to use external assemble for JsonObject, JsonLocalArray, JsonArray, JsonObject, and JsonToken (Newtonsoft.Json.Linq.JObject.'Newtonsoft.Json').
But what do you think about Http-"series" (e..g. I wanted to select right DotNet components)?
- HttpClient;
- HttpHeaders;
- HttpContent;
For some variables I d=found information (an example from old code - I did the investigation of 1297 "Http Web Request Mgt." and 1299 "Web Request Helper" codeunits and source code from other parts)):
- HttpRequestMessage;
- HttpResponseMessage;
But I'm not sure that I'm on right way, because I found some versions like below:
HttpStatusCode : DotNet "'System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Net.HttpStatusCode";
ResponseHeaders : DotNet "'System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Collections.Specialized.NameValueCollection";
HttpWebResponse : DotNet "'System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Net.HttpWebResponse";
HttpWebRequest : DotNet "'System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Net.HttpWebRequest";
Who has experience with this point? Do you have any information?
Thank you in advance for your help.
Related
Recommended
