Generating a SHA1 hash
Hi everyoe,
I'm trying to connect with a webService, and I must encode a part of the header with SHA1 encoding. I have an example in .NET, and I'm trying to convert it into C/AL, but I'm receiving an error from the webService. The code in .NET is this:
byte[] key = Encoding.UTF8.GetBytes(secret);
byte[] hmac_encode = Sha1Hash_Raw(concat, key);
string hmac_encode_base64 = System.Convert.ToBase64String(hmac_encode);
private static byte[] Sha1Hash_Raw(string input, byte[] key)
    HMACSHA1 sha1 = new HMACSHA1(key);
    byte[] byteArray = Encoding.UTF8.GetBytes(input);
    MemoryStream stream = new MemoryStream(byteArray);
    return sha1.ComputeHash(stream);
The value I must include into the header of the HTTP request is "hmac_encode_base64"
This is how I'm trying to generate the hash in NAV:
key := Encoding.UTF8.GetBytes(secret);
hmacSHA1 := hmacSHA1.Create;
hmacSHA1.Key  := key;
hmac_encode := hmacSHA1.ComputeHash(Encoding.UTF8.GetBytes(concat));
hmac_encode_base64 := Convert.ToBase64String(hmac_encode);
This are the variables:
secret    Text
key    DotNet    System.Array.'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
hmac_encode_base64    Text
hmacSHA1    DotNet    System.Security.Cryptography.HMACSHA1.'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
concat    Text
hmac_encode    DotNet    System.Array.'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
Does anyone see any mistake or something I'm loosing?
Thnak you very much
Related
Recommended
