An attempt was made to change an old version of a transfer header record in dynamics nav 2015
Hello Everyone,
I add two fields in Posted Transfer Shipment table Total Quantity and amount by using calcfield on Transfer Shipment Line table. To calculate amount against each item i use code and insert in Amount Field and modify that field. It work fine but is that when i create new transfer order it display an error message "An attempt was made to change an old version of a transfer header record. The record should be reread from the database."
This code i use to modify amount field.
TransShpLine.RESET;
TransShpLine.SETAUTOCALCFIELDS(TransShpLine.ItemAmount);
TransShpLine.SETRANGE(TransShpLine.Calculated,FALSE);
IF TransShpLine.FINDSET THEN REPEAT
    TransShpLine."Document No." := TransShpLine."Document No.";
    TransShpLine."Line No." := TransShpLine."Line No.";
    TransShpLine.Amount := (TransShpLine.Quantity * TransShpLine.ItemAmount);
    TransShpLine.Calculated := TRUE;
    TransShpLine.MODIFY;
UNTIL TransShpLine.NEXT = 0;
MESSAGE('Done');
Related
Recommended
