Json Parsing
I am working on parsing a Json response in NAV2015.
Thanks to Gunar's blog post http://www.dynamics.is/?p=2303#comment-1747 , and suggested modifications in the comments, I was able to parse one single Json object that had nested arrays.
Example: There are several accomplished events...
	"waybill": {
		"status": null,
		"number": "123456",
		"date": "2018-05-07",
		"flipAuth": false,
		"storageCharges": {
			"chargesApplicable": "N/A"
		"accomplishedEvents": [{
			"name": "Interchange Received ",
			"dateTime": "2018-05-07T17:00",
			"trainIdCarrierOrReason": "UP received from CCT",
			"location": {
				"city": "Ptstockto",
				"state": "CA"
			"name": "Yard Departure",
			"dateTime": "2018-05-08T22:03",
			"trainIdCarrierOrReason": "YSTST  08",
			"location": {
				"state": "CA"
But now what happens if I were to get several waybills back in my response?
Using the Posting Exch. Field Table 1221 to store the data after parsing, I think that I might be able to use the line number to differentiate between the different waybills, but haven't found a way to implement it.
Does anyone have any suggestions?
Here is the code I use to parse the Json response.
    PROCEDURE ReadJSon@5(VAR String@1000 : DotNet "'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.String";VAR TempPostingExchField@1002 : Record 1221);
    VAR
      JsonToken@1001 : DotNet "'Newtonsoft.Json, Version=4.5.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed'.Newtonsoft.Json.JsonToken";
      PrefixArray@1006 : DotNet "'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Array";
      PrefixString@1005 : DotNet "'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.String";
      PropertyName@1008 : Text;
      ColumnNo@1003 : Integer;
      InArray@1007 : ARRAY [250] OF Boolean;
      ArrayDepth@1102610000 : Integer;
    BEGIN
      PrefixArray := PrefixArray.CreateInstance(GETDOTNETTYPE(String),250);
      StringReader := StringReader.StringReader(String);
      JsonTextReader := JsonTextReader.JsonTextReader(StringReader);
      WHILE JsonTextReader.Read DO
        CASE TRUE OF
          JsonTextReader.TokenType.CompareTo(JsonToken.StartObject) = 0 :
          JsonTextReader.TokenType.CompareTo(JsonToken.StartArray) = 0 :
            BEGIN
              InArray[JsonTextReader.Depth + 1] := TRUE;
              ColumnNo := 0;
              ArrayDepth += 1;
            END;
          JsonTextReader.TokenType.CompareTo(JsonToken.StartConstructor) = 0 :
          JsonTextReader.TokenType.CompareTo(JsonToken.PropertyName) = 0 :
            BEGIN
               PrefixArray.SetValue(JsonTextReader.Value,JsonTextReader.Depth - ArrayDepth);
              IF JsonTextReader.Depth > 1 THEN BEGIN
                PrefixString := PrefixString.Join('.',PrefixArray,0,JsonTextReader.Depth - ArrayDepth);
                IF PrefixString.Length > 0 THEN
                  PropertyName := PrefixString.ToString + '.' + FORMAT(JsonTextReader.Value,0,9)
                ELSE
                  PropertyName := FORMAT(JsonTextReader.Value,0,9);
              END ELSE
            END;
          JsonTextReader.TokenType.CompareTo(JsonToken.String) = 0 ,
          JsonTextReader.TokenType.CompareTo(JsonToken.Integer) = 0 ,
          JsonTextReader.TokenType.CompareTo(JsonToken.Float) = 0 ,
          JsonTextReader.TokenType.CompareTo(JsonToken.Boolean) = 0 ,
          JsonTextReader.TokenType.CompareTo(JsonToken.Date) = 0 ,
          JsonTextReader.TokenType.CompareTo(JsonToken.Bytes) = 0 :
            BEGIN
              NewValue := FORMAT(JsonTextReader.Value,0,9);
              TempPostingExchField."Posting Exch. No." := JsonTextReader.Depth;
              TempPostingExchField."Line No." := JsonTextReader.LineNumber;
              TempPostingExchField."Column No." := ColumnNo;
              TempPostingExchField."Node ID" := PropertyName;
              TempPostingExchField.Value := FORMAT(JsonTextReader.Value,0,9);
              TempPostingExchField."Posting Exch. Line Def Code" := JsonTextReader.TokenType.ToString;
              IF NOT TempPostingExchField.INSERT THEN BEGIN
                //TODO
              END;
            END;
          JsonTextReader.TokenType.CompareTo(JsonToken.EndConstructor) = 0 :
            LineNo += 1;
          JsonTextReader.TokenType.CompareTo(JsonToken.EndArray) = 0 :
            BEGIN //add
              InArray[JsonTextReader.Depth + 1] := FALSE;
              ArrayDepth -= 1;
            END;
          JsonTextReader.TokenType.CompareTo(JsonToken.EndObject) = 0 :
            IF JsonTextReader.Depth > 0 THEN
              IF InArray[JsonTextReader.Depth] THEN
                ColumnNo += 1;
        END;
    END;
Related
Recommended
