Hi Everybody.
On Purchase Line of my include more Request Order. I want calculation Amount on all Request. But wrong.
This procedure only calculates 1 line. It can not repeat for the remaining lines by conditional :
RecRequisition.SETRANGE("Requisition No",RecPurchLine."Requisition No");
RecRequisition.RESET; RecRequisition.SETRANGE("Requisition No",RecPurchLine."Requisition No"); IF RecRequisition.FIND('+') THEN BEGIN REPEAT RecRequisition.SETRANGE("Requisition No",RecPurchLine."Requisition No"); RecRequisition.CALCSUMS(Amount); PRAmount:=RecRequisition.Amount; UNTIL RecRequisition.NEXT=0 ; END; MESSAGE(Txt0001,PRAmount);
Please help me fix code. Thanks so much
Best Regards,
Dinh Son
Hi Dinh,
What table is RecRequisition? And exactly what is it, that you're trying to calculate?
The second "RecRequisition.SETRANGE("Requisition No",RecPurchLine."Requisition No");" line certainly does not make anything for your code. It's just repeating a line.
But assuming that your tables/code otherwise is ok, then try to change
PRAmount := RecRequisition.Amount;
to
PRAmount += RecRequisition.Amount;
Thanks you Erik
Hi Erik
Thanks you, But it's not work.
Below is the structure of 2 tables. Please help me
Thanks so much
If you only have one purchase line per requisition no. then maybe that is why it is only returning one line...
Hi Erik.
Exactly it only returns one line. Please help me solution.
Thanks so much.
Yes, of course. You only have one purchase line per requisition no. and you filter on the requisition no. - so will only return one line.
You still have note written exactly what it is that you're actually trying to do?
Hi Erik,
I want to calculate the Amount of purchase requests versus the PO before receiving the goods into the warehouse.
Then you don't need all that code. This should be enough:
PROCEDURE GetRequisitionAmount(RequisitionNo: Integer): Decimal; BEGIN IF NOT Requisition.GET(RequisitionNo) then EXIT(0); EXIT(Requisition.Amount); END;
You need to define the variable in the function also, but then you can just call it where you need it.
Thanks Erik
I write procedure : define RequisitionNo type : Code
GetRequisitionAmount(RequisitionNo : Code[20]) : Decimal BEGIN IF NOT RecRequisition.GET(RecPurchLine.RequisitionNo) THEN EXIT(0); EXIT(RecRequisition.Amount); END;
then i call it by :
PRAmount:=GetRequisitionAmount(RecPurchLine.RequisitionNo);
MESSAGE(Txt000002,PRAmount);
But it's not work.
