production journal validation
can someone please suggest me about setting a validation on production journal
That when I open the productional if the RPO has no component it should give an error and should not open the productional journal. else it should be working accordingly.
Thanks in advance.
  • On the Released prod. order subpage there is a function which opens up the production journal. In there you have to add your code something like below
    Prodline.reset;
    prodline.setrange(status,prodline.status::released);
    prodline.setrange("prod. order no.","no.");
    if prodline.findset then begin
    repeat
    prodcomp.rest;
    prodcomp.setrange("prod. order no.",prodline."prod. order no.");
    prodcomp.setrange("prod. order line no.",prodline."line no.");
    if not prodcomp.find('-') then
    error('Prod. order component cannot be blank for prod. order no. %1 line no. %2',prodline."prod. order no.",prodline."line no.")
    until prodline.next = 0;
    end;
Related
Recommended
