Renaming primary key
Hey,
i have a separate table which contains list of items. I also subscribed to a onAfterRename event on item table. So when a item number is renamed, the item on the list should also be renamed. I cannot get it to work with RENAME function:
 Itemlist.SETFILTER("Item No.",xRec."No.");
 IF Itemlist.FINDSET THEN BEGIN
   REPEAT
     Itemlist.RENAME(Itemlist."Item No.",Rec."No.");
    UNTIL Itemlist.NEXT = 0;
  END;
Rec is the item record.
does anybody know what's the problem in above code?
Related
Recommended
